I've done it with a couple of Scythe Kama PWM fans tommy
Up to 1800rpm which offered pretty good cooling, they're pretty quiet. At 2k rpm, the noise increased, but was still not as loud as the 5870 reference cooler I had. At max of about 2450rpm, they're on the loud side.
I had them on the Alpenfohn Peter heatsink with great results and generally kept below 2k unless I was benching for absolute best results.
You remember the ghetto mod I did with the 120mm spectre fans on the Sapphire heatsink?
My results there pretty much proved that the slim heatsink was the limiting factor regardless of fan speed past a certain point and these 92mm Kamas definitely push a lot more air than the ones you'd find on most cards, so I reckon you wouldn't need to push more than 1800rpm odd with them on a stock sink with headroom left over should it be needed.
1800rpm on these is a hell of a lot quieter than those bloody spectres lol...
Depends on how loud is too loud for the individual I guess
You're right about needing to be on the ball with remembering to turn them up when needed though. With that adaptor you posted and a PWM Y splitter, he could just run them off the card as you say.
Wow, that post ended up a lot longer and more convoluted than I expected
