Just realised you need facebook for getting the code
Anyone able to send a spare please.
So another bad console port?
Plays just as **** as the Alpha did. Second GPU is not firing up. Getting around 50FPS using TXAA High 4XT 1 @1080p (It's not fluid at all). Also the art work looked awful with yellow lines and ****. I'd post a screen shot but it's probably breaking the EULA.
I thought Open Beta's lifted the EULA?
I didn't. Just logged into Origin and there was a link on the pop-up to get it.
Downloading now. Will be done in under 5mins![]()
you dont you just login origin and download![]()
however, since it is by EA, I didn't buy the game (and even more so since it is by Crytek) and even if I enjoy the multiplayer for crysis 3 I won't be buying for the same reason, will still play the SP another way though![]()
Refuse to support companies that are *****.
Well, I like it. It's similar to CoD in some ways but with longer kill times, better movement and more emphasis on headshots. All good in my book.
Also looks quite good in my opinion and I can't run it on max at 1680x1050 with a GTX 670. Some things very high and some things reduced to high.
