- 21 Sep 2009
- London
Can anyone else check Furmark on these drivers please?
Thanks a lot My GPU has just fired![]()
He didn't reply back Yes joke
Oh dear...I do hope you haven't put the curse on your GPU![]()
I touched wood before writing it![]()
That's a mental image i could do without.![]()
Back to uninstalling 'dem drivers.Those hand gestures aren't helping either.![]()
Just installed 13.1, now I just saw thisBack to uninstalling 'dem drivers.
Anyway, which is the best method for uninstalling drivers? I ususally go through controll panel, then Drive Sweeper, is this still a good way? And also, what is this new update for Drive Sweeper, Drive Fusion?
Dont use Fusion, Driver sweeper is fine. I control panel and remove driver and restart, Then run Driver sweeper and restart again and then install new driver.
Really just make sure once you remove the driver and after driver sweeper restart you should have the standard VGA mode where everything is massive icons etc.
Actually Driver Fusion is excellent and currently the only driver sweeping tool i would advise anyone to use, certainly on windows 8. Driver sweeper deletes system files that cannot be repaired or replaced on windows 8 by sfc /scannow.
I included a unlocked version of driver fusion in my AMD overclocking thread if anyone is interested.
Mmmm I been using Driver sweeper on Windows 8 since day one. I have now installed couple driver sets and used this program with no issue.
