What tubing size do you use?
18 Mar 2011
East London.
I'll start off.
I have only ever used 13mm ID 19mm OD, with compression fittings. However, as my rig is going through some maintenance at the moment im thinking about doing 13mm barbs with 11mm tubing or 10mm tubing and compression fittings.
Not quite sure how smaller tubing would look though :rolleyes:
I've used 1/2, 7/16 and 3/8 in different rigs and the 7/16 is definitely the best for me now. Use it with 1/2 barbs and no need for clamps.
3/8Id 5/8od, would love to lay my hands on some 1/2" fittings and tubing at some point, but don't think it'd be viable in a case as small as mine lol
im so undecided what to do.
think i may well drop down one size and do 7/16 ID - 5/8 OD comp fittings.
Anyone here use 10mm tubing? any chance of some pics so i can see how it looks in your respective rigs thank you :)
