- 16 May 2004
- Derby
Hi all. Not posted in here much but now is the time for my PC to get better and I need your help.
Currently I am using a pre-built "Primo 6100a" AMD A4-3300 2.50GHz DDR3 Dual Core System I got last year from our good friends here. I have also got a Sparkle GeForce GT 440 1GB GPU and two WD hard drives, one 1TB and one 500GB (the 500Gb was in with the pre-built system. The system has a OcUK 500w PSU. Basic black case.
Not sure if they still make the system I have so cant link to the exact specs but I know they have similar value ones now with possibly a higher spec, not be much though I don't think. I guess you experienced guys know what I have got and how it fares against other Value systems.
I am looking to fully upgrade these components:
Now, I am not 100% sure which order to upgrade. I was going to just get a new GPU so I could actually play games other than WoW. Something with a little kick so to speak but after having issues with W8 and the GT 440 I have gone back to W7 for the time being.
SO.... the plan is to upgrade a little every month in the order you guys think is best. The budget is around £100 - £150 per month with the chance of a £200 purchase along the lines at some point.
Yeah I could save and buy a pre-built system but prefer to get bits and build myself.
So guys. What do you think I should go for and in what order..
- CPU
- MOBO
- GPU
- PSU
- RAM
- CASE
- HARDDRIVE (SSD?)
