Anyone know of an app that can wake the device up using the volume buttons?
WidgetLocker no longer does this since i updated to latest PA rom :/
Android settings > lock screen > volume rocker wake.
Ahh thank you. I forgot i had to enable it in there rather than WidgetLocker
I've been using light flow for a while :Ehaha no worries, I've only just figured out it has its own LED notification controls too!I've been using light flow for a while :E
Where are they??
Im using LED Blinker at the moment.
I'd love to know how to make the menu bar a little transparent too. I know its possible within PA but have no idea how to do it..
Display > Pulse Notifcation Light & then you can set up custom ones there.
To get transparency on the menu bar go to Hybrid properties > apps > find your launcher > scroll over to colour & set the transparency there. Under either status bar or navigation.
That works. However, it does not apply it system wide :/
Launchig apps like Gmail, SMS and all the others changes it back to default colours/values
If you're on 4.1+ you can disable notifcations (this will include text ones though) in the app profile under app management.Best way to install Cerberus on a rooted phone?
The way I've done it currently - I've downloaded the apk from their website and installed via cwm?
Flash the .zip in revovery.
How does one go about sideloading apk and converting?![]()
Not sure if you can do it with every app but just check each & every app in the same area as the launcher one.
You can install it like a normal apk using a file explorer, then use something like Titanium Backup to convert it to a system app.
Or you can place the apk in the /system/app partition and reboot your phone.
Or you could just flash the zip in recovery, as it's much easier![]()
