No news about next update yet?
Seems to of gone silent.
Is this quite science based or can you pick it up and play from day 1 ?
	SNIP.
On a somewhat related note.. can you mark a fuel tank as empty before launch, or empty it on the pad quickly?
You could always put a mainsail on the bottom, and use those tower things to pin it to the launch pad. That should empty it pretty quickly, assuming the whole thing doesn't rip itself apart. Use a decoupler to cut it off afterwards.
But why would you want to do this? If you're building a petrol station in orbit, what use are empty tanks? It's very possible to get a full one up there.
I did think about this again after I write that. My plan was to take a load of empty ones up their on one trip, dock them all up, then full them with another mission. I.e build the station then fill it.
The thought did occur that I may as well just take big tanks.
The next part of the plan was it might be more efficient to launch a less powerful ship with a big empty tank, then fuel up in orbit. Rather than have lots of weight in stages just to get a heavy craft full of fuel up? I've got no experience/testing with it so far it was just an idea.
In the end I always seem to end up with huge lumbering ships in order to get the fuel I need up into orbit for the trips I want. Maybe put the fuel needed up separately from the ship might be easier? It's just something different to try as well.![]()
 Definitively one of the fun area's with KSP. You can manage your space program however you see fit.
Yep, I'm definitely not going to launch empty tanks for the purpose of connecting to the station for storage. That would be daft now I think about it. Docking practice is a lot of the reason it didn't go up with tanks, I've got the station up, now I want to stock it.
I'm still thinking about the idea of a lightweight ship with an already empty but big tank that I can fill when I'm up there from the station. Getting all that weight off the ground is the worst bit I guess. That's why the first stage of the Saturn V was so big. Lighter launch vehicle in terms of all that heavy fuel could be interesting I think. Also maybe a re-usable rocket, park it at the station and re-enter with just the command module.
Got to finish the station first though.![]()
The way I get a full orange tank into orbit is via a 6-sided asparagus configuration.
Like this:
http://i.imgur.com/ysAxbR8.jpg[IMG]
Notice the tanks around the outside are stacked 2 high to lift a single orange tank in the middle. That thing will get into a 100km orbit with fuel to spare in the final 2 side tanks, and the central tank completely full. I've been using it as an interplanetary tug to fly a small lander module around the kerbol system.[/QUOTE]
Cheers. :)
I was trying with four double tanks earlier and it didn't quite have enough umpf. I'll give it a go with that configuration next time I get a chance to play. :)
Cheers.
I was trying with four double tanks earlier and it didn't quite have enough umpf. I'll give it a go with that configuration next time I get a chance to play.![]()
Dont forget to utilise the asparagus system.
Without it your craft will consume fuel in the lifter stage quicker.
To explain, there Parralel or Asparagus:
Parralel: is 4-6 Double Tanks with Mainsails.
The Mainsails consume there own fuel + feed the Central Mainsale (Payload)
All Six Lifter Mainsales are jetissoned at 30-40km roughly.
Asparagus: is 4-6 Double Tanks with Mainsails.
The Mainsails consume there own fuel + feed the Central Mainsail (Payload). But there staged in Pairs of 2.
Pair A,B,C for 6 Lifter MainSails (Illustraited by SlyReapers picture.)
Pair A is connected to the Payload stage.
But recieves Fuel exclusively from Pair B.
Pair B Also recieves Fuel from Pair C.
This results in Pair C, draining very rapidly an jetissing at 5km.
Pair B then feeds the remaining engines, an usually drains st 15km.
Pair A then feeds the remaining engines, an lasts to 50-70km.
All the while you jettision spent tanks an surplus engines.![]()
Is there anyway to get pre-existing spacecraft? I find the whole building bit a bit of an effort when really what I'd rather do is practice orbiting, travelling to other world, landing, docking etc.
Also, how do I get the extra tutorials, did To the Mum pt 1 but I haven't got any others?
