Bro, I don't agree with any of that!
Firstly, white rice is a fantastic carb source for a backload. Pasta less so, but...
Secondly, it doesn't matter! If you fancy having a pasta meal, a backload is the PERFECT time for it. Is it optimal? No, but you're talking about a couple of percent difference to your daily outcome.
You should be trying to make this diet work for you, rather than restricting what you can have in your "cheat" portion of the day. Don't have brown rice/pasta, but don't worry about everything else. Even bread is ok.
C'mon man! There are thousands of meals you can cook. All you've done is default to the meals you normally turn to when you're cutting.
Low carb:
- salad with meat <---- that should be enough variety there anyway, most dressings are low carb too
- meaty soup
- stew
- meat and veg (this is where you live, but what about the other veg and meats!)
- chicken with avocado with olive oil and a splash of lemon
- tuna mayo
High carb:
- curry with loads of rice
- ANYTHING with loads of rice
- pasta meals
- anything high carb you've been craving
...in fact, this is too easy for me to carry on listing
You are making this WAY too difficult. Tbh you're massively setting yourself up to get sick of the diet.
You are completely right about white rice. I should aim to be less boring in the kitchen. I'm managing fine with the diet though.
Despite considerably upping my morning fat intake, it appears to me to be true. I'm just speaking from my personal experience, take it or leave it, that's how I felt. I am continuing to up my MCT intake.As I've said to you, this is false. If you're completely carb depleted, as in the prep phase, then maybe. But your body should be coping because you should be eating enough fats.
I can't really comment further on this as I was purely speculating. I'm not convinced either way. It certainly isn't 'normal' though.CBL is going to be better for your pancreas than most other things. Why? You're dealing with 1 insulin spike per day. Yes, it's a big spike, but compare this to the bad scenario of lots of spikes throughout the day, and not letting your levels return to baseline ever.
Agreed!You've already done the hard part (and it is very hard!) and are seeing good results, so now you need to be minimising difficult bits.
), cinnamon helps to improve sensitivity to insulin. One of the quirks of CBL is that this is actually the opposite of what you want to happen in terms of localised short term effect. Just to make up some numbers, assume that cinnamon would increase insulin sensitivity for 2 hours. That's great for the average Joe who's response is all jacked up, but CBL assumes that you've already got a balanced insulin response (either by default or because you've done the prep phase).
