- 1 Sep 2011
- York
CPU - i7 2700k @4.8
GPU - ATI 7970@ 1150/1600
@humbug - nothing left on the table, it crashed just after I took the screen shot. Can't be bothered to mess around with overvolting my cards.
Oh and you don't have me down for the red team and uksoldierboy doesn't have a GPU listed next to his score. Keep up the good work :up
The 2268 score was with mvp off.Page 6 and 7 updated.
@ Locky, astonishing run, well done, 8 Pack has just hung himself.
@ stephenb, your tied #5 with Kaap, you or he might want to do something about that.
@ Diagro, i looked at your scores again, they are off this world and half way to Tau Ceti for your clocks, everyone running 100Mhz higher overclocks are struggling to keep up with you, your iGPU is sure as sunset giving those scores a leg up.
I can't add those scores, if you uninstall your MVP and come back to me with the same scores then i will add them, not before that Intel HD carry on is gone from your results, ok?![]()
Will disable igpu in bios and rerun for you tomoz
Hi, you named my gpu as hd 7950 not 7970
the core is 1100 MHz not 1175MHz
and the mem as 1625 not 1525
Also. Why is my HD 7970 being out shined by a 7950 with the same cpu and speed?
You forgot to add LtMatt score http://forums.overclockers.co.uk/showpost.php?p=23795919&postcount=210
Nice scores Scotty. Very close to 1300 core there. Got any more life in the old girl or is she at her limits?
Nice scores @whyscotty
Do you recon that you could squeeze past 2253 for a single card if you wind your CPU up a bit.
I am looking forward to giving my HDs a go with the latest drivers I don't think I will get near the leaders but it should be fun.
I take it you meant 2353 ?
I accept the challenge![]()
