How much did your last m.o.t cost
I got a quote for 625 for my mot. Shall i take it elsewhere for a second opinion
£625? Given the wealth of information you've provided, I can safely conclude that that's a perfectly reasonable price for the work being carried out on your car.
Or you're being completely shafted, what do I know? How is anyone meant to know if that's reasonable :confused:
If that's just for the MOT, you're definitely being ripped off a wee bit
160k mile (at the time) Peugeot 406 2.1TD
Car cost £275, MOT cost £35.
Advisory for slight play in wheel bearing but passed with no work needing doing :)
I paid the max :( I took mine to a main dealer aiming to get simple stuff like brakes sorted if needed on the same day only to be told that they would have had to order them in anyway. Won't be making that mistake next time!
Last MOT was at my village garage, £40 all in including collection and drop off while i was at work from my driveway. (Leave the key outside for them).
Good service :)
£40 for the MOT
£2 for 2 bulbs (apparently they were blue not white, damn you ebay!)
£15 to weld an exhaust bracket on
could have been worse considering the bonnet doesn't really shut properly.
