*** The Official Nokia Lumia 620 Thread ***
I've been adding music from CD onto the 620, but I found the album art did not always appear. I found a way round it if you sync it using Media Player.
Does anyone know if theres a way round this, just seems a bit long winded to me just to get art to appear?
(I am using the Windows Music thats preinstalled).
I'll bump this. also handy tips for music on a Lumia welcome :cool:
Think I'll pick one of these up as an alternative to my Galaxy S2, and my first foray into windows mobile since my Orange SPV M600 running winmo 5.0!
Only problem is that it's out of stock online and in both the Stratford branches :(
Reading reviews this might be a handy wireless music player for the car, seeing as ive just tried pinning all my music to the start screen, that and plugging a 64gb card into one.
Absolutely loving this Nokia, had it a few weeks now. Not sure how I managed without it. It really is like taking your PC around with you, thanks to Windows 8.
Battery life is a big surprise, can go a few days if not used much.
Question about a weather app, I use the met office one, but doesnt seem to update unless i open it. When i look at background task is says its blocked, not sure how to unblock it?
Then music, should i stick with the default windows music player or is there a much better alternative? Seems fine apart from album art not showing sometimes.
There will probably be some setting in the application, but under the background task bit if you click on the app there is a tick box to re-enable background activities when you net open the app.
Personally I find the default music player fine...
Xbox music and Nokia Music work fine, they sync together perfectly, any reason why we have both on the phone? I see the Nokia offer location, ie gigs near you.. soz to be a noob on this im a late adopter.
How easy is it to unlock this? I'm on a Vodafone sim currently, but the O2 deal is £70 cheaper than a sim free or Vodafone PAYG phone.
You can unlock the phone from O2
My advice - get the phone from O2
edit - i use O2, and it runs Windows 8
Because it offers gig search and mix radio.
Shiny green shell arrived in the post today :)
It looks epic!
My Shiny orange one came today, it's one of those two tone ones, yellow underneath with a magenta outer, they dont seperate though.
Looks much better than the all black affair!
Is anyone here using theirs with a mSD card with music etc on it?..how does that work?
Im thinking how good a purchase one of these would be just for the car, Audio vis Bluetooth no sim in it, that and getting all the Nokia Drive etc would make this deal pretty damn sweet.
