If anyone with know how of an i7 3770k system help here please.
Originally Posted by Kaapstad
Originally Posted by RetrogamerX
We need to start a separate thread for this as I think the problem is with your system rather than the gtx 690, I have looked at the clocks and sli setup and setup in GPUz and they are fine.
When checking your scores on 3dmark11 you are scoring about 3000 points too low on the graphics.
We need some help from anyone who uses a 3770k setup.
Could you post your full system specs as there is something in there holding the card back. Could you use the link below
I am at work at the moment
Can you download and install driver 306.23 this is the best driver for a GTX 690.
Then rerun 3dmark11
At the moment your score is very low even at stock speeds.
Can you also post a screenshot of GPUz showing the clock speeds please.
here you go mate. I've oc the card a little, but even at stock it's a little lower then the score I gave earlier? My card is slow for some reason?
