Thanks fellas.
I was shocked myself how much of a difference it seemed to make. Before 1330 on the core was the limit, artifacts all over the place etc, now I can run 1350 no problem.
What was the BLK set at?
Thanks fellas.
670 SLI 1290/1880
i5 3570K 4.6Ghz
Modified Titan Drivers
Extreme HD Preset 1920X1080p
Sammy Green 2200Mhz
I've no idea, all I've done is change the bclk and I was able to push the GPU further. It's a clean install of Win 7 after I tested Windows 8.
Score: 2431
i5 @ 4.9GHz (48*103)
7970 @ 1370/1900
Big gratz Stonerdude the fresh install made the difference and in all fairness I never understood why you always scored lower then you should have lol, at one point I had almost the same score as you with my 7950, but with those clocks you should have been top on almost all benchmark's
That's why I never listen to those gimps who say just install over your old drivers.![]()
can someone tell an old git what MVP and BLK is?
Ta
Ps Humbug my card is in white text not redexcellent work though
I know and I know that CYPER is the one that pm'd the mods and OP on that forum.
Lock3h --- CPU@ 3930k 4.7 Ghz ---- GPU 7970 ; 1340 / 1900 ---- AVG. FPS 61.0 ---- Score 2514
Something fishy here, I don.t undertsand why you have lower score (2514) than people with 60,2.
How am I suppose to fit you there?
