- 13 Feb 2013
Hello there,
The system I have: http://www.overclockers.co.uk/showproduct.php?prodid=BU-136-OE
I wrote a post the other day about my Mobo not booting up.... I appears I forgot to add the ATX cables for the cpu
Anyways, I got it working yesterday and set about gaming, after 11pm the PC did a total shutdown. It was like someone pulled the plug on the thing.
After a little research I've found out it was the temp monitor kicking in.
So After unscrewing and rescrewing the heatsync, I'm still finding the CPU very hot.
Idle the machine is 17c ( or some what HWInfo64 & the "easytune" that came with the MoBo. ) But the cores are idle at 1397.5 MHZ.
When I game the auto boost kicks in (4.40GHZ ) and I the temps get crazy from there 80c underload, from my research the chip is only meant to take 70c before it shuts down..
This as you imagine has got me VERY worried. If your gonna check out the bundle please be aware what you see in the picture for a heatsync is not the one I got. The details are in the web page about which one I've got.
Now is that normal? ... my old Q6600 Quad core under load was 40-50c and idled around 15-20c.
Secondly what else can I do to ensure it never reaches 80c again.
Many thanks!
http://imageshack.us/photo/my-images/51/75014772.png/
EDIT: Just been stress testing the cores, max I could get out was 60c. Now when I'm playing BF3 then I get 80c + ..... I'm so confused atm!
Many thanks!
