Sounds like the power connector is just as fiddly.
What's your impression of the screen? Does it look significantly better than the RT or is it just sharper when you look more closely? Does text look any better on web pages?
Do the built in speakers sound better? I guess a larger body could help in that regard.
I guess the OS is a bit zippier than the RT, although to be fair whatever they did in the last firmware upgrade made a subtle but noticeable difference.
Text does look significantly better. The screen is much sharper and everything just pops out more. The screen is the first major difference I noticed. I love it. It could be used to read eBooks very easily although its too heavy to hold up for long!
Speakers are also much louder. They seem to be hidden under the heat vent so the sounds seems much more pronounced and more projected.
Its significantly snappier and more pleasurable to use than RT.
Don't get me wrong RT was a fantastic idea and works but you can feel it has issues and it doesn't quite seem ready, either that or the Tegra 3 inside is simply not powerful enough. Everything zips on here.
