Dell U2713HM vs Asus PB278Q
That's quite interesting even the difference in price!
How does the 7950 handle games maxed?
Thanks again :D
7950 does fine on everything bar Crysis 3 which has a bit of slowdown but tbh there seems to be lots of performance issues with it even on top spec and multi gpu cards.
I cannot remember the codes they have all expired now it was %40 off or something and free delivery. They was posted in the 2713HM thread but I think they were removed as being possible referal codes.
I would try it before you do and see how you get on. You could always run 1080p in the meantime it looks fine for gaming.
1080p is fine on U2713HM, I found this out myself when I received mine, some of my games were still set to 1080p. And it took me some time to notice that they all weren't.
All games are now set to 1440p thou. :p
Ok so I am going to go with the U2713HM. However the next question is shall I go with two of these? Or shall I go with 1 of these and then either 2x 24 inch or 2 x23 inch monitors?
What do you guys reckon? I'm finding it hard to decide!
Thanks :D
Thanks :D
Personally I prefer an odd number of monitors for gaming and for normal use. I have my main (middle monitor) and then my side accompanying monitors. An even number where you have to look left/right annoys me.
But three is odd? Sorry am I misunderstanding?
One in the middle and one left and right would be odd.
Thanks for the response :D
You said shall I go with 2 Dell U2713HM's :p
P.S.
My replacement also has Image retention, 3rd Dell U2713HM with issues. Must be bad batch.. Kinda hard to see in the picture but its very clear in the flesh.
[/QUOTE]
P.S.
That's pretty bad not had any issues with mine so far. Strange that you have had 3 with the same issue you sure they are not just sending the original one back.. :)
Lol well I like being able to have two maximised windows open at a time. I can't do this with a single 27 inch!
Fair enough I have two 720p windows open on mine when browsing split left and right which does me. I would struggle having a 27" + a pair of 24" to look at my brain would melt.. :)
Do you just do that in windows? You don't mean the normal left and right split do you as that wouldn't be 720p right? I'm assuming top and bottom?
Cheers :)
