- 28 Oct 2011
Ok well its the morning now here in Aus, so i will have a look tonight and see if there is somewhere i can upload it.
Note if you use torrents it can be had from there.
See below link for magnet to the file.
magnet:?xt=urn:btih:41b2a863e0f2b679d8f84afe832fd7a659205cd3&dn=Skyrim+Realistic+Overhaul+%28including+1.6+update+%2B+Dawnguard+text&tr=udp%3A%2F%2Ftracker.openbittorrent.com%3A80&tr=udp%3A%2F%2Ftracker.publicbt.com%3A80&tr=udp%3A%2F%2Ftracker.istole.it%3A6969&tr=udp%3A%2F%2Ftracker.ccc.de%3A80
Cheers, I've got the other required mods, and I've got over half of the others downloaded.
I never thought about searching for a torrent! - that's D/L'ing now.
Should be good to go sometime tomorrow, i've got a clean install. I'm assuming you just extract the rar's into their folders (I'll save the rars in another folder just in case I need them again) and run the batch file, then run SKYRIM from STEAM?
