i5 750 to ?
26 Mar 2007
Nottinghamshire
Motherboard has died so I thought its would probably be a good idea to change to a new CPU as well.
The question is what to as I've been out of the hardware loop for ages now and really don't want to be reading endless reviews of synthetic benchmarks as life is far too short and I'd rather get some actual user advice.
So is Piledriver worth a look or do I just buy Sandybridge?
Main use for the machine is gaming, ripping blu-ray to mkv and lots of photo editing.
I use 2 x-fired 5850's for gaming and so the motherboard will need to be compatible.
Thanks in advance.
It depends on whether you want something to tide you by or something to last.
If it helps any I built the system in my sig with exactly what you have in mind to do with your system (upgrading gfx today)
With the recent ridiculous price hikes on Intel cpu's i would pick up a second hand 1156 mobo and wait for Haswell. As you do a lot of editing and stuff i would have said X79 with a 3820 but even those cpu's have been hiked.
Budget is around £250 mark.
I looked the AMD 8320 and it seemed pretty good value compared to the intel variants.
Thoughts?
I can't really wait as I want to get some photo's edited as well as stave off a zombie apocalypse and the laptop just doesn't cut it. :D
The 3280's on a decent price and the 3570k was 161 yesterday.
Thoughts?
It'll likely be a downgrade/sidegrade in gaming, an overclocked i5 750 will easily go best an FX8320 in the majority of games.
For photo editing, it depends on the software.
It was clocked at 4ghz and performance wise I've been perfectly happy with it. If its about equal in gaming then I'm fine with it as I'm not really a frame-rate whore.
For editing I use Lightroom, Elements and Fast stone for images and Vegas, Premier and Handbrake for videos and its in these I'd like to think I would see some gain from a bit of shiny new hardware.
