- 13 Nov 2007
For these settings on 2560x1600 getting smooth fps in the 50s consistantly on 2x7950s and i7 920 @4.2 GHz
How far into the main game is that Humbug?
If it's not too far i'll do a comparison between 7970 (same clocks as Wolvers) against a 3770k.
I've not bothered to start this game up yet, so hopefully not too far.
The 8350 is meant to perform well in Crysis 3. Better than the 3570k.
wolvers, can you do me a favour? can you replicate my settings here, stand in the same place and take a screen shot with MSI AB running, i want to see what FPS and GPU usage your getting.
Please? thanks![]()
Can I go back without loosing my later saves?
3770k @4.7Ghz
7970 @1200/1750
I can replicate that later tonite, long after TopGear
It would help if you used MSI AB so we can see what your GPU is doing.
PS: Imageshack is really bad, slow loading... Photobucket is much better![]()
my 7950 windforce x3 is oc to 1200mhz and has no problems with heat or power but at random the game will lock up and crash to desktop
not so annoying single player but during multiplayer matches its annoying no idea whats causing it
Level 3 "The Root Of All Evil" its not far, but if your just stating it might take you a little while to get there.
So been using a moddded Trixx for overclocking instead (i get higher clocks thanks to more voltage![]()
Most likely to do with it also being programed to run on Consoles......Why cant you quick save like in Crysis 1? Checkpoints are the most annoying thing ever
Most likely to do with it also being programed to run on Consoles......![]()
Seems like more & more games are being made with only check point saves...Surely it cant be too hard to program in pressing a key to save/load a game![]()
