- 19 Oct 2002
- Shakespeare’s County
Hi guys.
I find my EP3 makes a strange noise when I come off the throttle. I understand that it isn't a quiet engine/gearbox, but I just want to make sure nothing is wrong.
Basically you'll be accelerating in low revs and the when you come off the throttle there is an ever so slight crunchy/rattly sorta noise, until you back on the throttle again.
Doesn't happen around any specific RPM, but normally lower gears/speed.
Any ideas? Or just the nature of the engine/gearbox.
Typical Honda input shaft bearing in the gearbox.
