What sort of settings should I be running this on:
i7-2600k
GTX670
SSD
16GB RAM
That performance is way off, i have a i7 930 clocked at 4ghz and a 7970 lightning with 1150 core and memory 1650mhz and all very high and 2x smaa and i get an average of anywere between 40-60 fps with occasional dip to high 30's.
You need to get that cpu and gpu clocked up you are loosing loads of performance as it is at the moment. Also i use dynamic vsync in radeon pro on this and it is smooth with no tearing.
^ Yep, cpu@4ghz and gpu something like a 670/680/7950/7970 and you can expect more than playable in very high at 1080p
Dont see the point in playing this in anything other than what this game is about. Max settings is what crysis series is about, its basically a playable fun benchmark. I cant play the game as intended so will either have to wait for a miracle patch/driver update or a new cpu and graphics card update.
You cant play it in very high on 670 SLI?
I was thinking that same but look at the res in his sig.
I ran crysis 3 with my GTX 580 SLI setup with all high settings plus a few set to very high at 1440pDont see the point in playing this in anything other than what this game is about. Max settings is what crysis series is about, its basically a playable fun benchmark. I cant play the game as intended so will either have to wait for a miracle patch/driver update or a new cpu and graphics card update.
@Wolvers, your 35 FPS vs my 30 FPS, what GPU is that?
So surely your GTX 670 SLI setup can ran crysis 3 with everything set to very high at 1440p![]()
