Win7 Sysprep (renaming pc to serial number)
26 May 2006
Edinburgh
Hello everyone,
I am starting a new image on a Windows 7 machine, I used to use compname.exe to rename Windows Xp machines to the serial number and this also allowed me to add a small prefix such as "XY-Serialnumberhere"
Anyway, compname.exe doesn't work with Windows 7 and I am having trouble finding an alternative.
What do you system admins use for renaming computers?
You might want to consider building the Windows 7 image out using the Microsoft Deployment Toolkit because you can use variables to insert things such as computer name as the serial.
In addition to the above, MDT acts as a common console and allows you to easily add drivers, applications and create task sequences to handle you desired preferences. For example, in this TechNet forums thread Michael Klitenberg provides a task sequence variable that will pull the mac address of a system and assign it as the computer name. In general, you would use the OSDComputerName variable to accomplish the kind of task you are describing.
The Microsoft Deployment Toolkit can be downloaded from the Deliver and Deploy Windows 7 page under the “Tools to Deploy Windows 7” section. MDT can even integrate with WDS which will allow you to multicast your deployments and push them out via PXE boot.
To become more familiar with MDT you might want to check out the following videos from the Springboard Series page on TechNet:
Deployment Day Session 1: Introduction to MDT 2012
Deployment Day Session 2: MDT 2012 Advanced
Another great video that I always recommend is Alphabet Soup Deployment: Understanding MDT, WDS, MAP, ACT, SCCM, and USMT.
I hope this helps and keep us posted on your progress!
Jessica
Windows Outreach Team – IT Pro
