Hi guys, I recently bought a new HDD (this one) for use as a media drive. It installed and formatted fine.
However, when I come to copy across some media files (.mkv) they all seem to be copying at ~70MB/s apart from one file, where I get a box saying "Invalid MS-DOS function". I get the options to skip, cancel or try again.
Any ideas? I've done a quick google search however they all seem to suggest no read/write permission or are going along those lines. However this particular file is not open in any program or is not being used in any way.
I've never seen this error before in my 15+ years using windows so I'd appreciate some info on what it actually means?
If it helps, I'm using Windows 7 x64, the file is approx 1GB (a film), both the source and destination HDD's are connected through sata 6gb/s and neither are my system drive.
Thank you
Thank you
