Heatshield rattle? Get a garage to get it up in the air...
I'd like a double-din unit also but decided against getting one equipped with nav as it's far too low down the centre console. You have to completely take your eyes off the road to glance at it.I'm also considering double-din nav units... They're so expensive though and it's tricky to find definitive information as to whether they'll fit properly..
Roughly 2,800 I thinkHaven't been able to shake the urge to get one of these.....some questions:
How many revs are you doing at 70mph in sixth?
Can be slow moving off from a standstill - especially if going uphill (even slightly) but once you are rolling it pulls strongly. You can make good progress in normal driving without ever going over 3,000rpm.What is the power delivery like? Does it pull well from ~1500rpm or do you need some revs on leaving junctions etc.
It can do both but if you're going to thrash it in a town environment the braking performance may disappoint you as it's not on par with the acceleration.Is it the kind of car you need to thrash to get the best out of or is it best as a relaxing cruiser? Or equally good both ways?
You get heated seats and full leather as standard on ST220s. With part leather you also get the option of cooled seats in addition I think.Can you get heated seats on the full leather or is it only on part leather?
Manual control from inside the car although some people have done a mod to make them auto on central locking.How do the folding mirrors work? Do they auto fold when you lock it or do you hold down a separate button on the key fob/interior of the car?
Not the best on the road as it's a decade old design but still a fair bit better than Halogen. The colour depends on the bulb fitted. I've got 5000k in mine but 4,300k is more common.How are the xenons? Are they really bright white light or kind of bluish?
See now a lot of people have said this but i found the braking is plenty good enough, it just isn't as assisted as modern cars which is good because you get a better feeling to the pedal, that said additional braking power on the ST220 can never be a bad thing if you ever decided to mod it
oh please tell me more, this would be so much better
I take it you fitted replacement bulbs then ?
Can you use any or is it a specific brand/type, have you noticed a significant difference on the road with the colour changed ?
My previous car (MK1 Focus) was a lot lighter and stopped quickly so I kinda expected more performance from the ST220's braking. Not saying it's rubbish - just could be better.See now a lot of people have said this but i found the braking is plenty good enough, it just isn't as assisted as modern cars which is good because you get a better feeling to the pedal, that said additional braking power on the ST220 can never be a bad thing if you ever decided to mod it
http://www.fordwiki.co.uk/index.php?title=Folding_Mirrors_With_Remote_KeyManual control from inside the car although some people have done a mod to make them auto on central locking.
Any 35W D2S HID bulb. The colour is mainly down to personal preference, it's the lumens you need to look at for performance.I take it you fitted replacement bulbs then ?
A word of warning though, the mirrors can get stuck in the closed position after a really cold night (ice build-up).
I have OSRAM 66240CBI bulbs (+20%) in mine. There's a pic of them in action on page 20 of this thread.
Page 20 for me is the last page, and this is page 21. Don't suppose you can link to the post instead can you ? or have I missed it somewhere ?
Were the bulbs easy enough to change ? enoughs space to get to them etc ?
I had actually found that link whilst waiting for you to reply, really good guide that, looks like a fairly simple concept but a fiddly assed job.
I may give it a go at some point.![]()
Are the front disks 300mm or 320mm?
Is there anything it doesn't need
http://forums.overclockers.co.uk/showpost.php?p=23780782&postcount=588
I did the bulbs at same time as upgrading from Halogen units. You have to remove the grill then pull the whole headlight unit out. Then you got easy access to the bulbs. Sounds worse than it is - you just got to undo a couple screws and twist some tabs.
