Yep.. its well worth the trade by putting the SSD in my laptop.. its like a new machine compared to the HDD that was in it![]()
Yeah i put one in my girls pc and she has an old socket 775. Makes a world of difference.
that still a huge difference though in fps.matt what sort of OC were you running to get that score?
I just ran the same settings and got 86FPS
Edit it appears i'm as blind as a batthat still a huge difference though in fps.
Yeah that would be good pal.That's what i thought, especially when i compared it to my extreme run. I even ran the test again to confirm the results were correct and they were. Was using 5ghz i7 and 7970 @1300/1823. could have pushed the gpu further to be honest.
I'd be happy to match your clocks on HIGH SSAA if you want to compare scores.
What settings are you using for world density?
seems your cpu is helping you perhaps?No problem pal i believe you,
Just ran extreme including world density on extreme and got 41fpsseems your cpu is helping you perhaps?
Only managed one run as my card starting throttling the clocks on the second go through.
same settings and I get 82fpsI dont get itsame settings and I get 82fps
Using 13.7 betas, you?
Im averaging these maxxed out on 2 x 6950 crossfire
that is at 1920 x 1200 do you want me to do one on 1920 x 1080?
