- 4 Oct 2011
Here are results on 1920 x 1080, it is actually worse which has surprised me a bit lol
Well that sucks,I'm using the same drivers. I think something in your system is wrong mate. Check this benchmark. A stock Ghz edition card gets more fps than your overclocked card.
EDIT
Maybe your cpu is holding you back? Other than that ive no idea.
Does this seem right guys?
Spec is:
i3 3220
7850 2GB
8GB DDR3
I often get micro-stutter because the FPS seems to fluctuate so much, one moment I can be getting 60FPS and as soon as I turn around or look into the distance etc it can drop to 40 which tends to cause micro stutter, it's worse when driving fast.
What can I tweak to get it running a bit smoother?
http://i47.tinypic.com/hs3pzd.jpg
1150/1650 I7 3770k 4.4ghz that looks fine?
vsync off
http://i45.tinypic.com/5n6804.jpg
shrink it or link it
Use the latest beta, 13.2 beta 7. Disable vsync.![]()
Can anyone advise at all? Stuttering is really getting annoying now... It's really bad when driving fast. Is something wrong with my rig?
It is camera shake when you drive fast not microstutter. I know its a pain isnt it and I messed about for ages before I realized what it was. It's because the camera moves in and out and makes it look like its lagging
Sleeping Dogs has borked itself on my computer, i wanna see how my 7950 holds up in a benchmark run![]()
Verify game cache on steam Night.
Yeah just did that a 2nd time and it finally fixed it
Here is a run at 1175/1500 no idea why the game says its a 7800 Series unless OcUK scammed me
Wouldn't complete the benchmark at 1650 on the memory, it was only stable at 1500 long enough to get a screenshot of the results before the display driver restarted.
