Flat first. You already have a perfectly functional car..
Ive been dreaming of both for a while, I doubt it'll be long in between the two purchases/rent or whatever you want to call it.
Was just thinking S2000 would be cheaper to buy now than in the summer.
It's not as though my rents are going to kick me out to move.
It's weather I get living sorted and then have a rough budget on car, or do I buy a car and then get a rough budget on flat rent...
What's the time frame on your parents retiring to Wales?
If you're going to rent a place then I'd be tempted to car it first.
But, if you're going to finance the car then I'd be tempted to sit tight for as long as you reasonably can without unfairly impacting your parents lives. Build up some cash, and once you've got a deposit you can decide whether buying your place or a new car is really what you want. Either way, you're not lining someone else's pockets.
Was awaiting a comment like this xD
The option isn't there, it's just which one gets the priority factor, car or flat.
