Having gone temporarily insane, I decided to buy a house, I then spent the best part of 2 years doing the place up, I thought I might share my adventure with you all. I really dropped myself in the deep end here, having not done more than put up shelves previously, I then went straight into a DIY loft conversion and bathroom refit, everyone thought I was bonkers but I showed em
Anyway, on with the photos, starting with the bathroom. This room was pretty grim when I moved in...
...and got much worse when I had to pull up the floor to sort some piping...
I started off stripping everything back to the stud work and brick...
Fitted a dropped ceiling so I could fit downlighters (loft room above stopped me going straight into the ceiling)...
Fitted insulation and plaster boarded...
I also put tile board on the walls, this stuff is insulated which is good for keeping condensation off the tiles. Amusingly enough, these things are held in place with studs called 'spankers'...
New pipes finished, my soldering skills could use some work...
New plywood floor goes down...
Bath goes in...
Shower tray goes in, and cubicle tanked (it's amazing how many people forget to do this, even waterproof grout is porous, so the wall starts to degrade from the damp after a couple of years if you don't tank it)...
Tiling begins...
Shower and cubicle in...
I love these taps...
Door hung...
Underfloor heating mat laid...
Stay tuned for the concluding part...
Bath goes in...
Tiling begins...
Door hung...
