Someone should send that to The Tech Report. I wonder if they will write another frame latency article on it. I'm guessing they won't.
Just got this. I have a AMD8320 @ 4Ghz and a 7850, it defaulted to high settings and runs a good 40-70FPS, mostly 60+ unless in an intense battle. Are there any suggested settings that will keep decent visuals but increase FPS?
also try downing shadow detail from high to medium. It increases fps by quite a bit and doesn't affect shadows much - Stand next to a shadow of yourself to see when changing from very high to medium
My settings (i5@4ghz, 670)
effects- Very
object- high
particales- very
post process- high
shading- high
shadows- medium
water- very
no motion blur
vsync off
1440p
I use similar settings, other than shadows on High, this on 1080P, it works well with good performance.
1080p all very high, 2xAA gets similar fps to those settings above and 1440p
No crashes for me on the new patch
You need more practice HumbugWorst shooting I have ever seen
its better to record / take photos with the fps counter showing
Surely Afterburner can record with it's own OSD?
