Good Mouse ???
13 Nov 2012
Welling
ive been using a hp wireless mouse for my laptop, however it seems to be broke as its not working properly for the last few days :( any ideas of a good budged wired/wireless mouse to get ?
By budged I am assuming you mean budget?
I have used the Razor Deathadder in the past and can recommend it. Might be a bit pricey at roughly £40. Logitech G9x is also decent and probably a similar price. Both with good DPI, mouse buttons 4 and 5, and perform well.
+1 on the g9x am waiting on mine to arrive in the post but researched into a lot and it seems to be a good mouse, lots of features, extra buttons and changable casing to suit your liking
One thing I would add about the G9x is that I have found the weights to be a bit useless for me. I use mine with no weights in and there is only one man alive who can use it with all 4 heaviest weights in, and that man is Thor.
lol :D
I use my g9x with all the heaviest weights and I like it.
The best function for me as an FPS gamer is the function button on the top that allows you to change the DPI on the fly. Great for changing between a spray weapon or pistol to a scope in any FPS game.
is the G9X a wireless or a wired mouse, im not sure what to get, would you recommend wired or wireless, thanks
the G9X and razor deathadder seem to be a little too pricey, ill probably buy something like them when i build my pc, any reccomendations for a cheaper one for my laptop ?
why is it hakank that you seem to keep making threads, you may seriously be looking for a mouse but was some of the other ones necessary? and you seem to keep making non constructive posts across the forums.
Love my CM Storm Sentinel Advance. Had it since release (the original one). The Sentinel Advances don't get much love :p
