Caporegime
- 12 Mar 2009
You sure? I'm not loaded but I don't mind helping you. Maybe sell the silvers then if you're still short I'll help.
You sure? I'm not loaded but I don't mind helping you. Maybe sell the silvers then if you're still short I'll help.![]()
Pedersen has good free kicks!
Look on YouTube for a free kick tutorial. I did, and I've since scored 3 from 4 (4th hit the bar). They are so easy once you know how (assuming you have someone with good free-kick accuracy and curve).Does he? Good to know...if I could take a decent free kick that isnt hitting some poor soul in the crowd or your defender in the face![]()
Brilliant - him and Cassano are probably the two best Serie A CAMs I've used.
I found Cavani decent with two strikers. As a lone striker his high/high work rates might leave you a bit stranded at the top of the field.
I've personally found IF Matri decent as a lone striker, 85 pace, 82 heading and 96 finishing.
Cheap too! Will only set you back 25k max.
Cheers! I might give him a go in place of Di Natale if I chop him in!
I'll never understand these stats - how can IF Matri have 96 finishing when his shooting is 77!?!?!?![]()
can anyone spec me a prem/la liga hybrid with podolski and benzema for 135k?
