Is it worth getting one ?
10 May 2012
North London
Wanted to ask is it worth getting a Joystick for BF3 when flying choppers n planes ...cos i cant fly them for toffee using the keyboard and mouse lol....and if it's worth it , what one should I be looking to get please ?, I dont want to spend too much though
thanx
thanx
do you have a ps3 or an xbox pad you can use ?
The pad works great.
Just pick it up whenever you jump into a plane/vehicle :)
+1 Get one with a wireless kit, then you can pull the battery pack out to turn it off to stop it rumbling over your desk.
As long as its switched on when you launch BF3 it will continue to be recognized after reconnecting it several times a game.
Plus on PC, the pads connection time is around .5 of a second!
I've got one of them ps3 pads which isn't Sony and it came with a USB for wireless support, any ideas if it will work with my pc ?
I have an old Sidewinder 2 force feedback joystick that I use for flying jets, it works ok and feels much better than using a pad.
Helicopters I find are better flown using K&M.
Yeah, what ever you choose find an empty sever and spend 10 - 20 mins practicing flying both jets and helicopters around, and learn the buttons for your countermeasures.
It will save on some of the abuse when a tree jumps up at you!
