I bought this in May 2011 and had it shipped all the way from California before Caselabs even had a website as they were operating from Overlock.net.
Since this case there have been other Caselabs released which you may want to consider.....
I was originally going for the Caselabs TH10 but i decided to go for the smaller M8 case, Extended top and pedestal for 2 reasons.
1.M8 case is a lot smaller,the TH10 is ****ing huge.
2.I Wanted to hide the rads from being seen,2 in the extended top and 2 in the pedestal and to also keep the ambient temps to a minimum inside the main case where the motherboard is.
I can use a total of 8 triple rads in this but i plan to use 4 which is complete Overkill.
2xtriple up top
2xtriple on bottom
2xtriple in pedestal
1xtriple psu door side mount
1xtriple front motherboard side in front of case mounted vertically
Total 8
Anyhow here is a few pics.
Very very well packaged.
Case,extended top(84mm) and Pedestal.
Top of case with Extended top
Top of case with Extended top removed,as you can see it has mountings for 2xtriple radiators.
Case and Extended top side by side,2 triple radiators will go here ontop of the case with the extended top covering them,they will be in push/pull fan config.
Front view with mobo door open and psu door open
Uploaded with
ImageShack.us
Motherboard door(clear glass although it looks blue with protective film covering it)
Psu door,this is where 1 or 2 psu's and hardrives will go,there is also room for another triple radiator on the side of the door.
Rear of case.
PEDESTAL,this is where 2 of the rads,2 pumps and reservoir will go.
Pedestal side view
Pedestal front view,koolance Reservoir can go here or a fan
Pedestal rear view which will house 2 fans as intakes for the radiators
Pedestal Internal view,as you can see it has 2xtriple radiator mounts,one on each side.
Screws,fittings,Caster mounts etc.
Old but Nice Build on youtube using some koolance QDC's.
Compilation of Official CaseLabs Photos + Links to Useful Threads
http://www.overclock.net/t/1060596/compilation-of-official-caselabs-photos-links-to-useful-threads
Lots of build logs, Mine is on there that i never actually got around to doing....
http://www.overclock.net/t/1226618/...-interviews-sketch-up-models-and-more-etc-etc
This is a nice tower based Caselabs.
CaseLabs STH10 Review
I also have 4x Rx360 rads, Koolance reservoir and 2xMcp655 pumps.
Its the ultimate watercooling case and destroys the Little devil and any case from Corsair, Infact it destroys any other watercooling case out there even the UFO case.
I did a lot of research before i bought it and i know its the best you can get
