- 17 Apr 2010
Hi,
Thought it would be helpful to show what I am currently doing to workaround the ridiculous 1.25v boost issue on my pair of 7950 HIS IceQ's. Hopefully this works for users with other cards as well.
1. Download the latest MSI Afterburner BETA (3.0 BETA 7 at the time of writing)
2. Disable ULPS if you are a CF user in 'Settings', 'General' tab. In the same tab also unlock voltage control, voltage monitoring and enable Force constant voltage (you may need to reboot at this point).
3. Create your first profile with your 2D core voltage settings. This is my setup, I also lowered the core clock down to 800.
4. Create a second overclocked profile settings, like so:-
5. Go back into settings, under the 'Profiles' tab, select your 2D profile as the first one you created, and the 3D profile as your overclocked profile, you could also get advanced with hot keys if you are so inclined.
Problem fixed.
Now my cards will run at 800 at 0.906v when required in the desktop and boost to 1050/1350 at 1.125v when gaming.
I haven't done an extensive amount of testing, but from this morning's gaming it seems to be working a treat
Chris.
Problem fixed.
Chris.
