Fifa 13
I just bought a new monitor, so I'm using a higher resolution. My game is running really slow, even though fraps reports 60fps constantly. All I've done is increased the resolution in fifaconfig :confused:
Any ideas? It's almost as if the game speed is in slow motion.
Using SLI or Crossfire by any chance? Disable it if you are
And did you all tick the micro-stutter box in the game settings before the game launches?
I wish there was something in fifa 13 that alerts you if the player is a quiter, that quits when there loosing, and when the game match makes you it would say something..
There is. This is the DNF%. If you put this on "match mine" in the settings then you won't play against anyone who quits more often than you do.
I'm running the game in SLI and have no stutter issues. I guess you've got to tweak it until you find the right settings that you're happy with took me a couple of days to find mine.
Windowed mode/No Limit fps/wait for vsync/disable aero all turned on.
Why dont a lot of people play fifa?
I dont understand why people prefer fifa on the console, I recently brought for the pc and i enjoy it so much better, just wish there was a bigger fan base on the pc really dont understand why theres not tbh :/
Not sure, but I know one thing I have always found a game so always thought lots of people played. Even in the team sections it has lots and lots of user teams, why do you think it has a low player base?
Yeah i always get a game fine but compared to the console the pc seems to be empty, like in ultimate team players are OVERRRR PRICED :/
