- 13 Nov 2007
What ever happened to the 8 core SB-E intel were supposed to be launching.
I think they need to hold something back for the next "BIG" Product Launches next year
I think your power consumption is massively over the top there besty.
You can get away with an 800W with a 3960x OC'ed and two Titans in SLI.
Yep
Intel really locked down Xeons this time around.
Imagine the bench scores you'd hit with 32 threads humming along at 4.5ghz+
Strange. Surely Intel would prefer gamers/overclockers invest in Xeon CPU's given the insane price tag attached!
Ivy-E aparently has room on the silicon for 12 physical cores compared to SB-E's 8 lol.
So intel are disabling half of the physical cores this time instead of just 2 like before xD
yeah, still gets beat by Quad Titans through, at least two peeps on the EVGA forums are reporting 1.6KW at the wall for those. Some dood fried his EVGA 1.5KW PSU using Quads.
I use that PSU, almost the first thing the manual tells the user to do is set single rail for multi GPUs. Would failure to do this fry the unit.
If these guys are pulling 1.6KW at the wall they must be modding the cards bios or something similar. I measured 3 Titans and a hex core all overclocked and the rig was pulling 1100watts at the wall, adding a 4th Titan should take this to about 1370watts.
What I can't figure out here is what the i7 Ivy-E 4820K 4c/8t offers over the i7 Haswell 4770k?
Not all of those will be true of 4770k vs 4820k, particularly the upgrade path.
Or just limit it so you can only run a single processor like the Xeon W3xx0 series.
Im not sure about the architecture that will be in the new consoles but AMD's current CPU's are not true 8 core processors just CPU's capable of handling 8 threads like Intel's i7's (though they do handle it better than the i7's even if per core performance is lacking). Piledriver doesn't have 8 separate cores it has 4 separate "modules" each consisting of two cores and shared cache/FPU. To use a simple analogy an 8 core Piledriver CPU is more like 4x dual core CPU's than it is like an 8 core Xeon.
