*** Bundymania Watercooling Parts & Systems Thread ***
I guess there is no need for a backplate for those cards at all..but hey...it´s a nice feature with this (new) cooling method for us H2O nerds ! :D
that titan block is the nuts
antony the heatkiller block for the 680 series by watercool.de
Awesome, that's what I picked out myself is it a good block?
Are these two compatible?
http://www.overclockers.co.uk/showproduct.php?prodid=WC-295-EK
http://www.overclockers.co.uk/showproduct.php?prodid=WC-219-EK
Also, what is the difference between Nickel and Copper blocks?
copper is just copper witth actel top, nickel is copper plated in nickel, copper darkens over time nickel dont.
think ek have sorted the nickel flaking issues as well so either would be good for you
Wonderful, thanks a lot.
Pick one up when I can afford to.
What's going in with the left rad in the second pic?? It's messing with my head!!
Phobya ddc top actually looks quite nice, they have improved quite a lot over the last year or so.
That's the bleed screw/drain port showing on the left rad. The opposite end tank has the 6 main in/out fittings. With any luck, my black XT45 240mm should be arriving tomorrow.
post #156
By all that is Holy, that is beautiful!
Manufacturers take note...make your cards look like that (no csq please)!
I've put off buying a gpu block because most are fugly.
My xt45 triple 180mm arrives tomorrow...yippeee!
