- 17 Apr 2010
Are you in fullscreen? CF wont enable if it's windowed.
Yes, I have tried custom and Extreme HD which forces full screen at 1920x1080
Well 3DMark 11 is giving me pretty decent scores, as is Heaven. Valley however only runs at circa 60% utilization on both cards which probably explains the low scores, for some reason the cards are not being stressed by this application enough. Clutching at straws here but perhaps the issue with this is linked to Windows 8 x64, AMD 13.3 BETA 3 drivers or my AMD 8350 creating a bottle neck.
I guess as long as other stress testing applications are utilizing the cards correctly there is not really a huge issue here, just odd that Valley displays these symptoms.
Chris.
Well I'm officially happy with my setup, might just avoid buying a 7950 to replace
trifire HD5870 1GB
CPU 1090T @ 4Ghz
all under water
<Pic>
You realise you're only running 4xAA?
Time for a better score
i7 920 @ 3Ghz
GTX660 superclocked 3Gb @ 1046 core & 6008 Mem.
Try 8xAA instead like the rest of us
lol
^^ probably a lot lot cooler than your 480 though SerpahX![]()
