[Guide] Project: Raspberry 3.14!
17 Aug 2012
Tamworth, UK
Raspberry 3.14 - A Project & A Guide!
Hi all,​
This is a project surrounding the Raspberry Pi which I have just kickstarted for my parents as they were after a media player which was more powerful than their 'Agoose' DVD player they had and the simplicity of using a external hard drive for films rather than lots of discs! This idea of this is just of course show a nice new computer being put together although it's simple and give a nice guide to how I completed it for anyone else who may be interested in what it can do overtime. I will be giving a indication of what items you will need and the cost of them as well.
Hardware Used - Components!
  • £33.00 - Raspberry Pi B Model
  • £1.00 - HDMI 1.5 Metre Gold Cable
  • £3.50 - Raspberry Case (Clear)
  • £5.10 - Belkin Ultra slim USB hub
  • £6.80 - Sandisk Ultra 10 class 8GB SDHC
  • £8.26 - Edimax wireless adapater 150Mbps
  • £5.00 - Micro Usb Charger 5V (Must be 5v+)
  • £1.00 - 3.5mm Audio Lead (If required)
These are all the components I bought and seem to be everything thats required to get everything rocking and rolling.
Setting it all up
So getting it all together, for such a small unit getting the case together was so damn tricky! Very fiddly and done my head in the end, so I do highly recommend you get a pre-built case to put the raspberry in or just go bare and not have one altogether. But here's some pictures that should show everything. Pi Pr0n! - Samsung S3 Phone camera quality sorry!
Got the girlfriend to put the case together in the end as I had given up, does look good when the thing is in there though. Everything just slots into the Pi as simple as that, will add some more picture for that later on when it's fully setup and working. But that will be explained further down.
Pictures should give an indication of how little stuff is needed and how the little the actual thing is, when they say credit card size, they were right! And it packs one hell of a punch for it's performance. But all shall be revealed later in the thread. Not the world best photo's however it does give a good indication of whats going on.
Software Used & Installation
So, from having it all setup and everything plugged in [Warning] when intially setting up the software when it's loaded onto the SDHC from windows/OSX it need to be directly plugged in via an ethernet cable, the Pi will load up the drivers for keyboards/mice however not for wireless adapaters so just a heads up. However I chose to use Raspbmc as my software for the Pi and it's the best suited for what my parents wanted and is quite simple to use.
Everything installed fine and setup after a 20 minute wait and I was ready to roll with the system. Starting up the device is easy as pie as well (pun excluded) all you have to do is put the micro usb power supply in and it loads up swiftly. XBMC has a nice interface which is simple and easy to use so getting new apps/add-ons which I am yet to do as I need to download the network interface for wireless, you can add BBC iPlayer, 4OD, Youtube & Navi-x which allows you to stream movies seamlessly, which is what I shall be doing.
Installing wireless & etc (To come)
Wireless is pretty much a simple task as long as you do it right, unlike what I did and just assumed that I would need to do some programming. Fortunately you can download and install a add-on called Network Manager, whilst on ethernet to connect wireless to a home hub/wireless point. I'll take some pictures of the screen and such, but it now works flawlessly on wireless and streams beautifully, even with the worlds smallest wireless adapter.
What streams/programs can the Raspberry Pi Handle?
So far, as a media centre the Raspberry Pi, can handle; 4oD, BBC iPlayer, ITV Player, Navi-X [Movie Streaming], SportsDevil [Sports Streaming]. It also can handle 1080p video playback from streaming and from USB/HDD's, with the ability to overclock to handle even more powerful files.
Netflix & LoveFilm are yet to be supported due to needing Silverlight to run them, and this isn't supported on Linux systems, however with Navi-X, this really isn't much of a problem as films can be streamed elsewhere, essentially.
This is excellent i am wanting a device like this which i can turn my tv into a media centre with netflix/lovefilm/4od/iplayer/itvplayer and internet browser/torrent ability. Will this do all of the above?
As it stands from my knowledge of using XBMC and some quick searching around, it seems Netflix/LoveFilm is still a no-go atm as they aren't supported on Linux, which is a shame as it would make the Pi even more fantastic.
It can handle everything you listed but Netflix and Lovefilm, there is uTorrent which can be downloaded as an add-on so I guess it will work all the same. But I'm yet to toy around with the internet side of things yet. That's to come tonight.
Have added some more information to the project, setting another one up for my Nan soon as they want to watch films/stream without the hassel of a computer, so I shall take more pictures during that install - Also it will be using the S-Video connectivity rather than HDMI so that should be something different to explore.
