**** Original Starcraft 2 Thread ****
Does anyone here use camera hotkeys? I've only noticed that pro players use them and are constantly bouncing around with them, but I just double tap my control groups when I want to move to my army etc. Should I learn to use them more efficiently, and where should I be putting them? Do you have to set camera positions everytime you start a game?
Just started playing again now HotS is out and enjoying the game a lot more than WoL.
Does anyone use a mechanical keyboard for SC2? Thinking of getting one to replace my ageing G15.
Not expecting it to improve my play but wondering if anyone has found the transition difficult to get used to when playing?
The general consensus is anything but Cherry MX red switches.
As Zerg it is absolutely critical, as the other races it is still pretty important for base management/defense though.
I use camera hotkeys. shift+F1,F2,F3,F4 and F5 to create them and then F1,F2,F3,F4 and F5 to jump between them. I use them to jump around my bases usually. And yes you have to set them everytime you start but it just becomes a normal thing, when I start I always just ctrl+4 then shift+f1.
Yep. Mechanical keyboards are generally just more comfortable to use for long periods, it won't improve your gameplay.
All switches are possible to use, I personally like reds and browns the best. It's all personal preference so get a test bag and find what you
Yep. Camera hotkeys are a key to improving.
Yes you have to set them every game, it's easy if you change the hotkeys to F1-F5.
Yeah I just got stomped by 3 masters in a row on ladder and slow scrolling back to my main base to build stuff was such a hindrance.
Do you just hotkey your bases ?
Yep, I'm sloppy as ****, mainly due to playing on the fly without refined build orders and getting supply blocked early, or usually when they come with 400 widow mines/hellions/marins at 4 minutes
Don't blame you, that first week of HotS was full of random playing XD
