I like them too, my next car will be a 3 GT M-Sport.
I really like em
What colour?
I have a flashing LED where the pin would be on a BMW.
Don't see the need for a door pin either tbh.
No idea yet, the M-Sport build config isn't up yet.What colour?
Comfort Access and Keyless Go allows me to get in the car and drive away without ever having to get the key out of my coat pocket. All of this means locks are out of my mind at all timesI had to laugh at the little knob thing or whatever you call it on the doors which move up and down when the door is locked/unlocked...something borrowed from Rover I think?
By the same token, if the BMW is well built, why is the dependability poor! That to me says, that they may look like they're built fine BUT infact they're not. If a product is built to a high standard, it'll last, if not it won't.
So, based on your Honda analogy, they may feel cheap BUT infact they still never break whether that's engines or cockpit internals otherwise this would be flagged as a fault surely of poor dependability.
I suppose it depends on what this "dependability" definition is... is it break down, is it buttons breaking etc.
I've had loads of BMW's, over 10 and I've had Ford's, Vauxhalls, Rovers, Alfas, Volvo's and others I can't remember over the years. BMW is a better quality product and I don't give a stuff what JD Power says. A 3 series is better to be in, better to drive, better to use, has a nicer engine and is better than a Mondeo. It's not about badge for me, never has been but they are objectively better in most areas of importance to me and I rate the Mondeo highly but have had cause to be in colleagues of late they are not the same quality. Swap Mondeo for some other mid ranger from some other brand and its the same. Most of my BMW's were faultless too but then so were most of my cars.
Agreed... just using some stats, without every variable, you have to start somewhere... we all hear that Toyota and Lexus have great reliability... and the facts back this up... I can't find anything that backs BMW's "myths"...They aren't as JD Power is a statistics management process without accounting for many of the things that determine reliability such as the type of driver.
So, based on your Honda analogy, they may feel cheap BUT infact they still never break whether that's engines or cockpit internals otherwise this would be flagged as a fault surely of poor dependability so just because it doesn't sound like a lead door when closing, does it do the same thing? Does it stop water getting in? Does it technically function as well as a BMW door. The answer is yes.
Lexus?
However I knew this would stir things up... just saying that's all...
[TW]Fox;24068386 said:Thing is, you can pay to fix a broken car but you can't pay to redesign a cheap interior.
