White knight build update time
29 Feb 2012
London
Hi guys this is my second WC build, I'm living in 2 places at the moment, so I've made a start getting the bits and some are here some back home.
3930k
16gb dominator gt
Asus rampage IV
2xTitans
TJ07 custom paint and modded to fit a 360 in the roof. Case arrives monday
AX1200
For the water cooling I'm using the
SR1 black ice 480 and 360 using corsiar AF120 fans
Tygon tubing 1/2 candy red coolant
Ek-FB kit re4 csq
Ek csq titan blocks, still waiting on them
Ek- Supremacy - CPU Waterblock - Nickel Plexi
I did get the ek blocks for the ram not sure if I'm going to use them yet
Using the xspc d5 pump/res combo
Last of all bitspower deluxe white compression fittings!!! They look amazing
More pictures to follow and I'll try make a start
id personally go for the quiet editions as the high performances ones are very loud
YOUR BASKET
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Dual Pack £25.99
1 x Corsair SP120 Quiet Series High Pressure Low Noise - Single Pack £13.99
1 x Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin £13.99
1 x Be Quiet! Silent Wings Fan Pure - 120mm £9.98
1 x OcUK Tech Labs - Zaward Golf III Fan 120mm ZG3-120TL TRIPLE PACK £7.99
Total : £81.85 (includes shipping : £8.25).
few options if your still looking
Thanks guys I have some food for thought :)
On another subject was thinking of some extenders or adapters for use between the
CPU block and mobo blocks, not sure if it would work? Bitspower do both in white but I've not seen the extenders anywhere apart from on there showcase website
I'm assuming the 360 rad will go down the bottom? (I know there's a mod to put a rad in the top, but not as thick as an SR-1 surely?)
How on earth will that fit in the bottom along with a Corsair AX1200 PSU?
The case im really pleased with it. I had bought the 900d but with the delays i decided to go with this.
Powder coated black!
The mod for the 360!
The psu will go in the left side
TITANS!!! i say it every morning
A selection of fittings! The last will arrive on the 20th of April and i'm still waiting on the titan WB's
Yeah, the site I saw that modded the TJ07 to accept 360mm rads in the top recommended 30mm (or less) thick rads I think. Which is why I thought a 55m might go in the bottom. I guess fans mounted on the top might be ok though. I guess you may get lucky if there's nothing very tall at the top of your motherboard?
I did plan on having it mounted inside. I'll have to do a dry build first to check it out.
Any ideas, maybe a slimmer rad in there, but also the fans on top of the grill as there white
The 2350rpm high performance edition ones?
I am using the above fans on my rig, yes they are a bit loud. For me it does not matter as I am slightly deaf but for someone with sensitive hearing it could be too much.
These give the same performance but are a lot quieter.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-030-SY&groupid=701&catid=2331&subcat=4
