- 19 Dec 2008
- London, UK
Hi chaps,
Have anyone of you guys heard about the 'Leap Motion' motion controller? I heard about it recently and i thought i would share with people that are unaware of said device.
It's a very small device that you put under your computer screen, using 2 infra-red cameras and some sorcery it can plot your hand perfectly on the screen.
https://www.leapmotion.com/
From the demos of the prototypes it looked like it just worked as they said. It also works on Macs and Windows, If it works with Windows 8 flawlessly i see it being a major success and that's not to mention all the other possibilities a new input device like this could offer. No need for expensive touchscreens
At around $80 i'm definitely interested in such an inventive device. It's out in May but you can pre-order now. I think it's worth holding out till launch but if it's as got as they say im sure they won't be able to make them fast enough
Only concern it how far will it integrate with existing software or will be just be limited to it's own app store, even if that's the case it won't be long till someones hacked it anyway
What do you guys think about this new motion controller?
