Overheating Issue
Sounds like poor CPU to waterblock heat transfer or coolant is not circulating like it's supposed to.
Is the waterblock on CPU warmer to the touch than one of the hoses? (the hose carrying the coolant from pump to radiator) The hottest point in system should be the hose carrying coolant from CPU to radiator.
Reason I ask is because if pump motor is running you will feel / hear it but the pump impeller is not moving than no water is moving through the loop.. so no heat will move away from waterblock/cpu.
Will test on days off and update. Thanks :)
Is the waterblock on CPU warmer to the touch than one of the hose (the hose carrying the coolant from pump to radiator) The hottest point in system should be the hose carrying coolant from CPU to radiator.
Hi just tested this. The machine started at 39 degree the went 89 degrees idle in BIOS! Yes the block seems warmer than hoses. Does this mean the cooling block is not doing what it should be? After turning off machine, radiator and hoses are cool to the touch but block is still warm.
My guess is coolant is not circulating.
May sound like a silly question but what next then? If you can supply a link on what I need to get that would be good :p
Also, just out of interest, what is stopping the CPU birning out completely?
As you have a CLC you probably need a new cooling system. I have no idea if your system is still under warranty but if it is try that route.
CPU's self regulate and throttle and/or shutdown automatically to try and keep from burning out.
Thanks. Just trying to enquire whether I am still under Warranty for issue.
Errmmm...whats CLC?
Not under warranty anymore. Received this rezponse :( :
"...Hi there unfortunately your system is not under warranty, but I am guessing you have a h20 flow cooler the pump may have failed a like for like replacement is a h80i..."
Quick question...will the h80i just fit exactly the same place as my current cooler?
I don't use CLC because of known issues with their pumps. Some like H series have had several models with a history of problems. I assume you paid £55 your OcUK H²Flo Extreme a couple years ago.
My suggestion is get a nice air cooler. You have 177mm cpu clearance in your CM 690 II (from CM's website). Plenty of room for any cooler I can think of. I don't know how tall your Kingston HyperX Genesis Grey 8GB RAM is. If it stands less than 40mm above motherboard most coolers will fit over it. Silver Arrow SB-E has least clearance with 39mm. Top air coolers are between £54-70.00 and will cool as good as what you had.
Air coolers have virtually no problems. Occasionally a fan dies but is easily replaced. Air coolers are cheaper, quieter, usually cooler better and more dependable. I'm still using a Thermalright Ultra-120A from 2006... I did replace the fan. ;)
If you decide to go air I can make more specific suggestions.
I can't remember how much I paid but the H80i will cost around £70-£80. What air cooler could you suggest then, and how would I fit this over my original setup. I.e. radiator and fan, etc. ?
Well Alpenfohn K2, Phanteks PH-TC14PE, Noctua NH-D14 and maybe Thermalright Silver Arrow SB-E (3 models) are arguably the best. Not sure all will fit over your RAM. Could yo measure how high it stand above your motherboard? All are between $54-70.
What were your temps before you had problems with your system?
I will have to measure on days off as I am working again tonight. I have been told that a 775 heat sink and fan should be sufficient? Whats your advice on this as I haven't a clue what that is and how it performs?
Your 2500 is a 1155 so different spacing to 775. Your case will fit 177mm over CPU and CPU is 8mm above mobo so 185mm. If your RAM is about 40mm above mobo you can fit a 140mm fan over RAM. If that's true you can use any cooler you want. I prefer big cooler because they can take more heat away from CPU with less fan speed.. so you get a quieter system.. assuming your GPU is quiet. And I like quiet systems. If you don't need as much cooling as your old CLC was capable of than you can use a lower cost cooler. These are thinsg I need to know in order to give you good advice.
Ok. Will do measurements as soon as I can. Can you tell me what you need measuring again please?
Good! You can use any cooler you want.
The Silver Arrow SB-E Extreme is £53.99 It comes with TY-143 2500rpm fans which add about 8c more cooling when ran at full speed of 2500rpm at 45dba. But if you keep it below 1300rpm it's the same noise level as normal SA SB-E at 25dba. Fans are PWM
http://www.overclockers.co.uk/showproduct.php?prodid=HS-099-TR&groupid=701&catid=2330&subcat=2352
Archon SB-E X2 £59.99 2x 140mm PWM fans. Single tower that cools as good as twin towers
http://www.overclockers.co.uk/showproduct.php?prodid=HS-106-TR&groupid=701&catid=2330&subcat=2352
Phanteks PH-TC14PE comes in white(silver cooler) £66.98 and other colors of red, blue, orange and black £69.98. not PWM fans but come with a PWM adapter
http://www.overclockers.co.uk/showproduct.php?prodid=HS-009-PT&groupid=701&catid=2330&subcat=2348
There's a white (silver) Phanteks TC14PE for £54.98 if your interested
http://www.overclockers.co.uk/showproduct.php?prodid=BG-006-PT&groupid=595&catid=678
Alpenfohn K2 £59.99 with 140mm and 120mm PWM fans
http://www.overclockers.co.uk/showproduct.php?prodid=HS-020-AL
Noctua NH-D14 £62.98 with 140 and 120mm non PWM fans
http://www.overclockers.co.uk/showproduct.php?prodid=HS-011-NC&groupid=701&catid=2330&subcat=2346
Normal Silver Arrow SB-E £57.98 PWM fans
http://www.overclockers.co.uk/showproduct.php?prodid=HS-078-TR&groupid=701&catid=2330&subcat=2352
Silver Arrow SB-E SE £59.99 PWM fans
http://www.overclockers.co.uk/showproduct.php?prodid=HS-101-TR&groupid=701&catid=2330&subcat=2352
BeQuiet! Dark Rock Pro 2 £61.99 135mm and 120mm PWM fans
http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-BQ&groupid=701&catid=2330&subcat=2340
Black Megahalems £49.98 plus fans
http://www.overclockers.co.uk/showproduct.php?prodid=HS-019-PL&groupid=701&catid=2330&subcat=2349
and Blue Megahalems £48.19 plus fans
http://www.overclockers.co.uk/showproduct.php?prodid=HS-026-PL&groupid=701&catid=2330&subcat=2349
and Silver Megahalems £42.98 plus fans
http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-PL&groupid=701&catid=2330&subcat=2349
I know it's a big list.. and these are only the best quickly off the top of my weak mind. I'm sure I've missed a few. Honestly most are all about the same cooling. It's more you liking one more than another.
