- 22 Mar 2009
You can install your own extension wiring, but you shouldn't mess with the BT side of the master socket.
I agree!
I agree!
how will they know?
Ill just blame previous owner/ sky engineer ect ect.
I'm aware that legally only BT can touch 'their' side of the master socket, not you.
Good question. But, I think BT system will stamped time and date at your local exchange of deactivated your line and reactivated line. And BT can check if there is any engineer is booked at that time, if not, then BT know u had messed it and take legal action against you, only if the line won't be back online.
It's up to u. Beware of the big bills if u need BT to come out again.
I be totally amazing if you managed to move master socket and the line is working!![]()
Why do you need to move the master socket in the first place? Extension wiring and an extension faceplates will perform the same.
fibre needs to be plugged in to the master socket as far as i understand.
BT system at the local exchange does recording all actives on your line with broadband too for any diagnostic fault via BT Retail & your Service Provider (for broadband fault)
The filtered faceplate supplied by BT has two sets of punchdown terminals. One set for any voice extensions and another set for the VDSL side. Both can be extended to another location.
so are you saying bt could use the existing wiring to extend to another location
If you extend BT's wiring with a soldering iron they will know that someone has been messing with it.
im not saying they wouldnt know that some has been messing with the master connection by the soldered joint.
im saying they couldnt prove it was me that done it.
They don't need to make a case that'll stand up to 'beyond reasonable doubt', they just need to know that their wiring has been interfered with.
Moving a master socket isn't difficult, it's just not advisable. In the unlikely case that something goes wrong you could end-up with hassle you don't need. The most likely problem would be dealing with any potential line faults in the future.
You can do what you want just by running good quality extension cabling from the master socket. The master sockets are designed to accept punched down extension wiring, so why not do it the easy way?
i have good quality extension cable installed to 2 other face plates.
i thought the vdsl faceplate had to be installed at where bt cable entered the building (master socket) and this was where the modem and router had to be plugged in?
No, the VDSL can be extended as well. There are dedicated terminals in the filtered faceplate that BT supply for it. This is basically what the 30 metre extension option offered by BT is.
There will need to be a cable from the master socket to where the modem will be. I have two voice lines and my VDSL signal running through three pairs of a length of Cat5e, works fine.
Real Openreach engineer or a contractor?
My install is tomorrow got mine yesterday.
Posted on their forums?
