**** MAN Vs RAM ****
15 May 2012
Louth, lincs
In this thread i would like to compile a list of Ram from all the various manufacturers with there stock speed/timings and settings that you folks have achieved through overclocking.
This list will help others determine what Ram to possibly buy for there build and to achieve there best system performance/effiency.
Many people will say just get the cheapest 1600MHz kit out there as it makes hardly any difference, in most cases this is correct, but this is an overclockers forum and a few seconds shaved off here and a few more FPS there can mean everything. :D
I find myself looking on other forums to find this kind of information out, i want it here on OCUK's forums.
This list will potentially help others in overclocking there Ram and give them a ball park figure to aim for, many times Ram is forgotten, its generally all about the cpu but most of us know what a 3770k, 2500k or a 3930k should possibly achieve through an overclock but we dont know what most Ram can do, so this is what this list is for.
So for this list here is an example of what i want.
Make/model/stock clocks,timings,volts/OC clocks,timingsvolts/part no./socket/board manufacturer and finaly model.
G Skill Ripjaws Z 2133MHz 9-11-10-28-1T, 1.65v/OC 2446MHz 10-12-11-28-1T, 1.69v
Part No. F3-17000CL9Q2-32GBZH/X79 ASUS R4E
I shall enter this info as a list in the post below, if you would like to post a benchmark such as SuperPi that is fine but no score will be added, this an informative thread and not a league table. When more than 1 of the same part number is entered i will edit the list to include the max possible overclock.
Memory related BSOD's
0x0A = unstable RAM/IMC, increase QPI first, if that doesn't work increase vcore
0x1A = Memory management error. It usually means a bad stick of Ram. Test with Memtest or whatever you prefer. Try raising your Ram voltage
0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances
0x50 = RAM timings/Frequency or uncore multi unstable, increase RAM voltage or adjust QPI/VTT, or lower uncore if you're higher than 2x
0x109 = Not enough or too Much memory voltage
Downloads
Superpi 1.5, for benchmarking your ram http://www.putme.net/SuperPI150.zip
Memtest86, for checking your Ram's stabillity http://www.memtest.org/download/4.20/memtest86+-4.20.usb.installer.zip
MemTweakit, for changing Ram settings in windows, http://www.softpedia.com/progDownload/Mem-TweakIt-Download-190641.html
Maxxmem, gives bandwidth/latency readout's http://www.maxxpi.net/modules/download_gallery/dlc.php?file=15
Aida64, all round benchmarking suite http://www.aida64.com/downloads/aida64extreme285exe
Prime95 for stability http://www.softpedia.com/progDownload/Prime95-Download-76537.html
Passmark, benchmark suite http://www.passmark.com/download/pt_download.htm
Thanks for your time.
**************RAM LIST****************
CORSAIR
Corsair Vengeance 1600mhz 9-9-9-24-1T 1.5v kit/OC 1640mhz 10-10-10-28-1T 1.65v -CMZ16GX3M4A1600C9B - Gigabyte GA-X79-UD
Corsair Dominator plats 1866mhz kit 10-12-12-28 1T 2475mhz 1,75v /x79
Corsair Dominator plats 2400mhz Kit 9-11-11-28 1T 1.75v /x79
G SKILL
Part No. F3-17000CL9Q2-32GBZH/X79 ASUS R4E/MSI Xpower II
GSKILL Ripjawz PSC kit 8-12-9-28 1T 2500+mhz 1.85v/x79
SKILL Trident X 2700mhz 10-12-12-25 1T 1.85v, 3165mhz 11-13-13-35 2T 1.85v/z77
GSKILL Ripjaws air 2544 8-12-8-28 1T 1.9v LN2 2600/z77
G Skill Ripjaws Z 2133MHz 9-11-10-28-1T, 1.65v/OC 2640MHz 11-13-12-30-1T, 1.68v
Part No. F3-17000CL9Q2-32GBZH/ Gigabyte P55A-UD4
KINGSTON
Kingston HyperX 2400mhz 11-13-11-31-2T 1.65v/OC 2420mhz 11-12-11-31-1T - KHX2400C11D3K4/8GX - MSI Xpower II X79
SAMSUNG
Samsung Green 1600mhz 11-11-11-28-1T 1.35v/OC **OC broken on MSI X79** - MV-3V4G3D/USx2 - MSI Xpower II X79
Samsung Green 1600Mhz 11-11-11-28-1N, 1.35v/OC 2133Mhz 9-10-10-21-1T, 1.58v
Part No. MV-3V4G3D/US/Z77 ASUS MVG
Samsung Green 2400mhz 9-12-12-21 1T 1.65v, 2666mhz 11-13-13-25 1T 1.75v/z77
Samsung Green
Stock: 1600mhz 11-11-11-28-1T 1.35v
Overclocked: 2133 9-10-10-21-1T-88 1.65v with Tuned 2nd and 3rds
Overclocked: 2333 10-11-11-21-1T-96 1.65v with Un-tuned 2nd and 3rds X79 ASUS
Samsung Green 1600Mhz 11-11-11-28-1T, 1.35v/OC 2133Mhz 10-10-10-21-1T, 1.45v
Z77 ASUS MVG
TEAM
Team Xtream 2600mhz Kit 2500+mhz 9-11-11-28 1T 1.75v/x79
16GB (4x4GB) Corsair Vengeance 1600mhz 9-9-9-24-1T 1.5v kit/OC 1640mhz 10-10-10-28-1T 1.65v -CMZ16GX3M4A1600C9B - Gigabyte GA-X79-UD7
16GB (4x4GB) Samsung Green 1600mhz 11-11-11-28-1T 1.35v/OC **OC broken on MSI X79** - MV-3V4G3D/USx2 - MSI Xpower II X79
8GB (4x2GB) Kingston HyperX 2400mhz 11-13-11-31-2T 1.65v/OC 2420mhz 11-12-11-31-1T - KHX2400C11D3K4/8GX - MSI Xpower II X79
8GB (4x2GB) G.Skill RipjawsZ 2133mhz 9-11-10-28-1T/OC **awaiting delivery** - F3-17000CL9Q-8GBZH - MSI Xpower II X79
G.skill kit should be with me tomorrow so I'll update then.
Samsung Green 1600Mhz 11-11-11-28-1N, 1.35v/OC 2133Mhz 9-10-10-22-1T, 1.5750v
Part No. MV-3V4G3D/US/Z77 ASUS P8 Z77 V PRO.
Heres a few of mine.
X79
GSKILL Ripjawz as above 10-12-11-28 1T at 2500+mhz 1.75v
Z77
GSKILL Trident X 2700mhz 10-12-12-25 1T 1.85v, 3165mhz 11-13-13-35 2T 1.85v
GSKILL Ripjaws air 2544 8-12-8-28 1T 1.9v LN2 2600+ 6-11-7-24 1T 1.95v
Corsair 2800mhz kit, 2850mhz 11-14-13-31 1T 1.85v
I have tested endless RAM and have some new stuff now for Haswell so I will update this post as need be.
I nearly bought the same gskill memory that your waiting on pgi but manages to get hold of my current ram for a very good price, and it overclocks incredibly well, could probably go further with someone who knows what their doing with ram overclocking. If I remember correctly, the ram you have purchased should overclock very well. Have fun and enjoy :-)
Surprised on some of the high voltages on some of the samsung green ram here.
I get
Z77 ASUS MVG
They used to, not sure why they don't anymore, perhaps to push the team group stuff?
I did find something the other week from a hardware rep saying something like g.skill & corsair get first pick of IC's and the rest pretty much get the leftovers. Which is probably why Kingston, geil etc... only put out poorer but cheaper dimms.
Perhaps someone from ocers would care to explain why Gskill is missing from their range???
Mark
Samsung Green
MV-3V4G3D/US
X79
Asus Sabertooth
