Warranty Direct?
13 Dec 2002
Newcastle upon Tyne
I know they have been mentioned before but just after any advice wether positive or negative regarding Warranty Direct
I recently purchased a 2006 BMW 330D M Sport Auto. I bought it from a trader so technically got no warranty. I started to look into aftermarket ones as I wouldnt be able to get a BMW one.
Warranty direct have thrown up two choices
Extra Care with 100% Parts (upto value of car) and 100% Labour (upto £200 per hour) for either £600 for one year or £1000 for 2 years
or
Extra Care Lite for 60% parts and 100% labour for £135 a year, the only thing being is that the car has to be recovered to garage to qualify
Both have £50 excess the first has no limits to claims and the lite 5 claims (I doubt i would be making 5 claims a year)
trying to weigh up the pro's and cons of both and would welcome any suggestions.
I'm thinking along the lines of say for example the auto transmission packs in, it would be fully covered on the extracare cover technically but on the lite id have to pay 40% of the cost which is likely to be a lot more than the full cover costs.
Maybe i'm being paranoid but it could be worth it for the peace of mind, although I need to know wether the dealerships are happy to deal with them directly first otherwise it would be a total waste.
22 Jan 2005
West London
Why can't you get the BMW Warranty?
I am paying around £43 a month for my BMW Comprehensive Warranty with zero excess sub 60k miles, and I bought my car privately.
Caporegime
20 May 2007
Surrey
Unless they have changed things, even with extracare you will have to pay a parts contribution for betterment. On a 2006 with under 80K miles they will pay 70%.
The whole "has to be recovered from a garage thing" sounds a bit rubbish. So your car basically has to be undrivable for them to even start to think on paying out???
I took out an extracare policy with them knowing full well that these warranty companies can be a nightmare. It was however only ~£250 for 13 months cover and they cover for wear and tear after the first three months. I haggled for ages and brought them down about £150 (NEVER take their first quote) and got all their extras chucked in aswell (airbags e.t.c)
It might be money down the drain but it is a little bit of peace of mind. If it was as much as the £600 they quoted you i would have just saved the money and crossed my fingers.
22 Dec 2002
Minehead
My clios cambelt slipped and I had a WD policy. Hire car cover isn't included as it might seem.
It took them over a week to get an engineer out to authorise the claim for new valves, leaving me without a car for the week. Why? Because the job doesn't take more than eight hours to complete, so whilst I had no car for almost 9 days, they wouldn't cover a hire car at all.
You also do have to make a parts contribution based on the mileage as has been said.
4 Nov 2003
Ashford
You would be better off putting the monthly premium in the bank rather than paying WD. At least then you will have something towards the repair instead of them wriggling out and you having to pay anyway. They have far to many loose exclusions to get out of claims and they aren't afraid of using them. I was without my car for three weeks fighting them and in the end gave up when BMW offered to cover the parts.
26 Jun 2011
On my LS430 they paid for a PCV, some sensor, a wheel bearing and 2 lambda sensors in 1 year between 71k - 82k.
Everything was at a Lexus dealer apart from the bearing.
They paid upfront for the dealer jobs. They gave a cheque for the bearing.
No hassle. The bearing was making some noise, took it do an indy, indy called WD, they gave the go ahead and all was sorted.
OP
13 Dec 2002
Newcastle upon Tyne
is that from experience or speculation?
22 Dec 2002
Minehead
I'd say from what he wrote... its experience ;)
Tea Drinker
Don
13 Apr 2010
Sunny Sussex
From experience WD is less peace of mind and more of a gamble, they will wriggle and squirm not to pay out of any claim and the betterment payments plus excess means what you get back is less than you hope.
26 Jun 2011
What the fudge is so diffucult about dealing with this company.
Keep a full service history with a VAT registered garage.
Keep an MOT,
Claim on items that are specifically in the handbook for the cover you have chosen.
When you suspect an issue you raise the ticket with them first, tell them you are now taking it to the garage. They will wait for the garage to call them.
Take the car to the garage, tell them youre with WD, garage will talk to them, confirm the issue and the part is covered and done. Finished.
I found it incredibly easy, the previous owner also found it incredibly easy for the other 4 claims.
Man of Honour
17 Oct 2002
I have to completely agree with Dandle. I was once an advocate of WD following a few simple no hassle claims but in the end my experience of them mirrored his.
The problem arises when something complicated goes wrong where it isn't clear what the fault is. If your widgit quite obviously breaks and the cover lists widgits then its plain sailing but many failures, especially with more complex cars, are not this clear cut.
11 Oct 2003
Somerset
You won't find all dealerships will deal with these crooks directly, you'll have to do the legwork and pay the invoice after they have authorised the repair. They (WD) will reimburse you.
7 Nov 2002
Snorbans, UK
Thanks for that, not as bad as I thought £737 for a fully comprehensive cover with £100 excess
Given the positive experience that many people on this forum have had with the Insured Warranty, I'd be going with it tbh. WD seem to have quite a few exceptions, whereas the BMW Warranty seems to cover most eventualities.
