- 15 May 2012
- Louth, lincs
if only i had a 3930 for this
Scores updated![]()
Down on just over 2000 points on Kaap's overhall P'score! Dont know why the difference is so great.
In this bench CPU speed and fast tight memory really distort the final score.
On the standard settings it is not even worth me running my Titans as the CPU holds them back too much and the results are dreadful, on the Extreme preset things are a little different as the Titans can get to work.
http://www.3dmark.com/hall-of-fame-2/3dmark+vantage+3dmark+score+extreme+preset/version+1.1
thx gregstergot a 3930 comming soon so see what i can do then
Yeah memory tuning is something im not up to speed with. I've noticed your graphics score is a lot higher also.
Ah! I'll work a little on improving the Cpu speed then. Are you clocking on just the Multiplier or using a combination of Multiplier and bclk? Drivers used for this run were the 306.23 one's.
For this bench I normally use the 100 strap multiplier.
You can score a tiny bit more on graphics using the 125 strap and raising the bclk a bit to around 129 but most of the time I find it is not worth it as it makes the system unstable.
I found the 125 strap and bclk was the sweet spot for me. I wasn't stable enough on 129 and 100 just didn't net enough points on the GPU.
Same here! I need to work on ram tuning aswell. Ram speed currently running at 2400MHz timings at 11,12,11,32 1T.
Which benifits benchmarks the most, higher speeds with loser timings or lower speeds with tighter timings?
The problem with raising the bclk is it effects a lot of stuff line the PCI-E slots and puts more strain on the IMC.
8 Pack showed me something interesting the other day, when running 4 cards benching, use PCI-E 2.0 not 3.0
This sounds crazy but it works, it makes the CPU more stable @high overclocks as the CPU has less work/stress with PCI-E 2.0, I find even though the cards are running less efficiently they still get more done due to the CPU running more stable.
I am not sure, I find they both help. If I had to choose I would say getting the timings tight is slightly more important then comes memory speed.
I run my memory @2400mhz 9-11-11-25 1T 96 24/7 but when I get in from work tomorrow I will try a few runs on the 3dmark11 physics test with different speeds and timings. If you have any you want me to try please let me know. I will do a run at the timings you are using but if you have any more please let know and also what CPU speed you want.
