Gaming system - £750 budget.
28 Feb 2004
North East, UK
Hi,
Could anyone suggest a gaming build including a monitor for £750 please? Been out of the loop so not sure what's best etc. Will need a case and PSU. Many thanks!
PSU isnt powerful enough for the 7950 and doesnt have enough connectors.
The board you chose is severely limiting
Case is quite crap
Yes it is. Easily.
Molex to 6 pin adapter, about £1.
Only if the OP will be overclocking loads, but I have amended it.
Case is quite crap
Actually the case is quite good, especially at the price point. It's certainly better made than the Source 210 that you specced.
Changing the mobo to the D3H was wise. Not sure if an optical drive is needed but I balanced my build out to include one.
I'm sorry but I'm not a fan of the Merc case either it's terribly basic. Only one fan and no USB3 ports really does go against it, the Asgard Pro is a better alternative. I will confess to having styled my spec ever so slightly. Not that the 7850 is a bad GPU as they overclock well but a 7870XT or a 7950 would be better still.
YOUR BASKET
1 x Sapphire HD 7870 XT rev2.0 2048MB GDDR5 PCI-Express Graphics Card with Tomb Raider & Bioshock PC Games £209.99
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x Samsung S22B300BS 22" Widescreen LED Monitor - Glossy Black £99.95
1 x Gigabyte Z77-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £83.99
1 x Corsair Builder Series CX 500w Modular '80 Plus Bronze' Power Supply (CP-9020059-UK) £54.98
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £48.95
1 x Adata XPG Gaming v1.0 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AX3U1600GC4G9-2G) £37.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x OcUK 24x DVD±RW SATA ReWriter (Black) - OEM £12.95
Total : £761.77 (includes shipping : FREE).
Amended spec which is less "flash for the cash". The 7870XT is closely related to the 7950 and overclocking it will net you 7950 performance although it does only have 2GB of VRAM rather than the 3GB the 7950 offers. The MSI 7950 is hit and miss on reliability from what forum members have said, might be best to avoid it to save headaches.
Hopefully there are enough suggestions now for the OP to balance out something he likes :)
Thanks. There may be a possibility of an extra £100 to stretch the budget to £850. How would the extra be better spent? On a better GPU?
Looking at the builds above I think they are spot on for your needs.
If I had the extra 100 notes I'd spend it on an SSD or upgrade the monitor to a 120hz model.
Yes it is. Easily.
You are better off getting a 500W PSU than buying an extra molex to 6 pin. These arent terribly good PSU's. I wouldn't trust one.
The board has less ports, worse onboard sound plus a bunch of other stuff. If your getting the K edition CPU its almost pointless getting that board.
The case isnt good and how is it better then the Source 210? Have you actually read any reviews. The Source also has a dust filter, 2 fans, better cablemanagement and USB 3.
