Your CPU might be at it's limit? Vsync?
At stock, my 3570k bottlenecked a bit, (gtx 670 @ 1310/7560). Clocking the cpu to 4.5ghz helped a great deal, though minimum fps were still lower than my old i7 [email protected].
Aye, not a bad card mate. It'd probably go a bit higher with the modded 1.2v bios. But i cba to flash it.Your 670 clocks like a beast.![]()
Get clocking! The 8350 is quite the weapon for BF3
This
The 8350 does shine in BF3, even if it turns out that your CPU isn't bottlenecking, a decent clock on the 8350 and you will get a nice performance boost anyway.
Cheers mate would 4.4-4.5ghz be a good one? Need a decent air cooler and one that would fit my case any recommendations?
What does that command do?
